Hello. Went to check the levels on Fred and I have no brakes, suspension or steering. She was fine when I parked a couple of days ago. Auxiliary belt is good.
Suspect the pump but before I take it off is there anything else I should check for?
Thanks! It's a bit hot here and I'm boiling!
Xantia - no brakes, suspension or steering
Jaf
- x 42
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
- x 1486
Re: Xantia - no brakes, suspension or steering
If there is LHM in the tank and no power steering with the engine running, then you probably have an air-lock in the pipe from the reservoir to the pump. Probably also a loose connection on that hose.
You may need to disconnect the.hose at the reservoir and fill it with LHM to prime the pump.
Jaf
- x 42
Thanks. I'll check the pipes later when it's cooler.
Jaf
- x 42
Aha! Squishy bit of pipe where it's tied to the pump. Hopefully that's it, will repair tomorrow.
Jaf
- x 42
You were right! I've had to use a join to the original pipe as the new pipe fits on the pump but not the reservoir as the pipe is too small. Obviously can't find a citroen pipe so this repair will have to do. You were right about priming the pump too.
Thank you.
Thank you.
