Peugeot 508 2.0 HDi 163km Oil leak
Szakal80x
Hi. I have an oil leak on the back of the engine. it is not a standard high pressure pump. oil is leaking through the valve cover gasket. that is a common occurrence in this engine. sereis also recommends replacing the valve cover. Does anyone have a service manual to replace the valve cover gasket? Peugeot 508 teraz 2013, 2.0 HDi 163 HP.
