Peugeot boxer electrical
TZDunnit
Unread post by TZDunnit »
Strange issue with headlight / indicator
When locking/unlocking the nearside headlight flashes not the indicator and vice versa the Indicator comes on when the high beam is selected and there is a buzzing coming from the offside headlight, the left indicators flasher relay is clicking a lot faster than normal with no flashing of the front bulb, swapped out all the bulbs for new made no difference.
90 Bx TZD Turbo ven red 294k
74 D Super 5 Black.??? K
65 Boxer van workhorse 438k
Volvo v50 d
Nissan Juke
TZDunnit
Re: Peugeot boxer electrical
OK so the plot thickens...
I have now noted that when my headlights are on and I switch off the ignition and take the key out all the dash lights stay on (as if the key is in position 2) although the engine switches off as normal.
Also the headlight tilt adjuster comes on for about 15 seconds when the headlights are switched on/off on the offside, these can only be adjusted manually via the buttons and should not come on automatically
There is also a faint glow in the high beam bulb on the offside
Via process of elimination the dash lights problem is something to do with the nearside headlight as I removed the sidelight/indicator/high beam bulbs from that side and everything is fine
Nearside indicator rear and mirror are fine but no front
Offside indicators are ok
Headlights appear to be ok
No front nearside drl
At the mo no high beam as I have removed the bulbs
My guess is a grounding prob in the headlight itself??
My limit has been reached
Any ideas?
Faulty headlight/s??
Indicator/light stalk/switch??
Volvo v50 d
Nissan Juke
gazzaman2k
Unread post by gazzaman2k »
i take it you never sorted this problem? i got one here with same issue
