Smelly 2.0hdi
Martinez
x 19
Smelly 2.0hdi
Unread post by Martinez »
Berlingo 2001 90bhp engine. Done 180,000. Runs like a Swiss watch and no smoke. But it smells like an old paraffin heater.
Any know fix for this ?
Also, fumes are getting into cab and mrs is complaining. Exhaust leak ? Can’t see anything, but it does get worse if you open the window.
Cheers guys
x 1240
Re: Smelly 2.0hdi
Unread post by Peter.N. »
Possibly a diesel leak on to a hot engine or exhaust, examine the injector connections.
x 2941
Re: Smelly 2.0hdi
The tailgate/boot sealing can cause that, the exhaust fumes get sucked in as you procced forward if the seal is damaged.
TZDunnit
Re: Smelly 2.0hdi
Unread post by TZDunnit »
If it smells like paraffin or what I call an old traction engine it may be your EGR valve, I had this on my citroen relay and the top hat had broken off the valve, complete loss of power and loads of smoke to boot.
90 Bx TZD Turbo ven red 294k
74 D Super 5 Black.??? K
65 Boxer van workhorse 438k
Volvo v50 d
Nissan Juke
Martinez
x 19
Re: Smelly 2.0hdi
Well, it flies through emissions test every year. So have doubts about EGR valve failing. It’s a Motorhome so no rear door seal issue although the back is permanently vented. I’ve had other diesel cars and never smelt anything like this.
If it’s a diesel leak where’s the place to look ? I’ll point out it stinks much worse on outside, so suggests to me it’s an exhaust leak.
