Hi all,
I have recently purchased a 2015 DS5, which I love. I am trying to work out how to set the Jukebox up. The option is greyed out and I have no idea how to upload my music files on to it. Please could anybody tell me how to do it? Many thanks.
2015 DS5 - Jukebox help
- x 6954
Re: 2015 DS5 - Jukebox help
Pop your VIN up first, so we can identify the correct system you have. Not all systems have a Jukebox function (especially the later ones).
skragamuffin
hi i know this is an old post but i have the same issue please see my VIN
many thanks
Paul
many thanks
Paul
- x 6954
@skragamuffin:
You have several options and I'm not sure you really need 'Jukebox' function now:
1) You can copy MP3 music files rom a PC to a USB memory stick (Formatted to FAT32 standard) and insert this into the USB port in the vehicle. The system will generate a playlist from the contents (may take a few minutes depending on the number of files). Once a USB is detected, the SOURCE setting on the Head Unti will then show a USB as a valid option - you can play your music directly.
2) Connect a smartphone via Bluetooth - you can then make phone calls and stream music from the phone to the vehicle's audio system.
3) The system will support older methods of playing media files from iPods or music stored on an iPhone via cable connection of the device to the USB port.
4) You can copy files from a USB to the internal storage of the Head Unit (Jukebox), the storage is limited to 8 Gb.
Everything is in the manual.
