Have just replaced the radiator of the bosses Saxo SX diesel, non a/c and non abs. The manual says run engine until the fan cuts in, after about 20- 30 mins not a sign of the dam thing spinning, looking at Haynes she has either a single speed or two speed fan. On the two speed fan there should be a relay somewhere, where should it be? its not in the fuse box on the nearside in the engine bay, actually there are no relays in there. Not sure If the car has one or two speeds, if I can locate the relay if there is one it would be a start.
Any advise?
Steve
saxo rad fan relay
civvie
- x 21
