Car will not start with the Fan belt installed
Jammydodgers
Unread post by Jammydodgers »
Im really hoping someone can help as this is driving me crazy.
I have a Citroen Dispatch 2 with the DV6 16.HDI engine.
Cam belt broke and it dmaged the rockers and Cam.
New cam and rockers installed and all timed up. Took it out for a test drive and its perfect, however the moment I install the Auxiliary belt the car refuses to start!
If i take the belt back off it runs fine.
Does anyone have any ideas of what it could be? Its not the crank sensor as it runs fine with the fan belt off and its definitely not the timing.
Many thanks
TZDunnit
Re: Car will not start with the Fan belt installed
Unread post by TZDunnit »
Do you mean it won't turn over or turns over but won't fire up?
90 Bx TZD Turbo ven red 294k
74 D Super 5 Black.??? K
65 Boxer van workhorse 438k
Volvo v50 d
Nissan Juke
x 1506
Check that something is not seized on the aux belt route - PAS pump / Alternator / tensioner.
Jammydodgers
It turns over, but it wont fire up. it will almost catches, but then nothing.
Pas it not seize, new water pump turns freely as does the alternaltor.
Steve Walsh
x 521
Unread post by Steve Walsh »
Try unpluging the small sensing wire from the back of the alternator and trying it
Jammydodgers
Ammendment, took the aux belt back off, and it still wont start. was starting perfectly well until i fitted the aux belt.
as before, it turns over fine, almost fires but doesnt.. double checked timing, all ok
x 1506
Is this a stretch belt? Did you turn it backwards when fitting?
Jammydodgers
Solved: When fitting the Aux belt it must have moved the Crank position sensor slighty. re-adjusted the sensor and all fine.
