Windows Up-Down Remote control
DamirMitrovic
x 4
Unread post by DamirMitrovic »
Stopped lowering and raising the window over the key remote stopped working.
Peugeot 508
Years 2011
1.6
DamirMitrovic
x 4
Re: Windows Up-Down Remote control
any help?
Huskyxantia
x 888
Unread post by Huskyxantia »
How do you get an avatar like yours ? How does it animate too?
Battery in fob ? Or a dirty earth ?
:-D
DamirMitrovic
x 4
I did not understand? The battery is NEW
Huskyxantia
x 888
DamirMitrovic wrote: 28 May 2022, 22:30
Ok, new fob battery, what about the loom to the power windows possible bad earth contact ? Maybe a receiver issue ?
Something that receives the signal from the remote fob could be breaking down ?
:-D
x 1990
Unread post by Stickyfinger »
I would start with a full BSI/Battery reset...
follow it to the letter/times........... viewtopic.php?t=61997
DamirMitrovic
x 4
Huskyxantia wrote: 29 May 2022, 08:30
It happens that sometimes the passenger's window from the driver's command works normally. Sometimes he doesn't react! Also lifting and lowering over the remote sometimes works sometimes not.
x 1056
Unread post by wheeler »
Can you confirm that the remote operates the central locking as normal but just doesent operate the windows?
do the windows operate as the should from the door switches?
Is it the original remote control or aftermarket?
If the answer to all the above are yes, i would try a BSI reset inc resync the remote(s) first. If that doesent work it may be a configuration issue.
If the central locking is working off the remote i cant see it being a receiver issue.
DamirMitrovic
x 4
I can also unlock with a remote control. The switch doesn't just work on the driver's side. I also changed the whole main dashboard with switches, and it only button works on the passenger side.
