Octopus pipe.. :-(
philhoward
Octopus pipe.. :-(
Unread post by philhoward »
Off to fit an octopus pipe...wish me luck! Could Citroen have put it in a worse place to get to???
If it's done before either a) it rains, or b) it gets dark, then it's also stage one of the LPG conversion!!!!
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
All the best! It's several years since I had the joy.
philhoward
Only an hour of actual work, and only one pipe left to connect - the black one from the rear end!! Just can't get at it to hold it, now the rest are connected. It had split the same place as the last one I did on the old 19RD; the pipe to the front HC, on the corrugated bit.
Why do I seem to buy BX's with duff Octopi???
philhoward
Done - 2 hours work and it's leak free!!!!
