A friend has a 1.6 306 Petrol, L reg, which is giving incorrect lambda on an emissions test, and has the injection ecu warning-lamp lit.
Just did a quick recce today, and I think I may have spotted the problem already, as the lambda sensor has been changed in the past, and it looks to be a very cowboyish job, with taped-on wiring.
-Anyway, I just wondered if any of the gurus knew the ECU faultcodes for this model?
Also do you stock a replacement lambda sensor, if it turns out to be needed?
