Coding with diagbox
SanderG
New User
Coding with diagbox
Unread post by SanderG »
How to code in the second hand abs pump on Peugeot 3008 with diagbox?
x 6945
Re: Coding with diagbox
When replacing the hydraulic valve bock
  • Configure the ECU (you will probably need to locate the replacement parts section for this and follow the procedure - however it may require connected mode to do this. I can't advise as to the configuration, but likely will include engine code , transmission type etc., etc.
  • Calibrate the steering wheel angle sensor
  • Read and clear the fault codes
