whats the difference?(AX)
ZXturbo_Aura
Unread post by ZXturbo_Aura »
hi all, gave in and bought a ax debut 954cc injection! strictly talking about the engine, what is the difference from the GT engine? apart from the obvious displacement difference???? interested in knowing to help me with modifying my little ax! thanks in advance!
Dan
Simon Canfer
Unread post by Simon Canfer »
AFAIK the GT is a 1360cc with twin-carb.
Had a 14TZS a while back; almost GT performance but with 5 doors; great fun!
Simon Canfer
ZXturbo_Aura
i thought standard GT's had only one carb? apart from displacement and compression i cant see much difference, not enough to give it the extra power anyway!lol
Dan
philhoward
Unread post by philhoward »
I think it's a twin-choke carb - one for the cheesesliceking, me thinks!
cheesesliceking
Unread post by cheesesliceking »
Hello People!
Here's some info on the AX GT[:D]
<u>Engine:</u>
capacity = 1360 cc
bore x stroke = 75 x 77
cylinders, valves = 4 cylinders, 8 valves
compression = 9.3 to 1
fuel system = <b>1</b> double Solex Carburetor
max power = 85 bhp/ 6400 rpm
max torque = 115 Nm/ 4000 rpm
0-60 = 8.5 Secs[:0][:p]
Max Speed = 112Mph
<u>Dimensions:</u>
wheelbase = 2280 mm
weight = <font color="red"><b>709</b></font id="red"> kg [:0][:0][:0]
Insurance Group = 9 [;)]
ZXturbo_Aura
cheeselicking... need som help.. how can i improve my little ax until i finally can afford to insure it with a transplanted gt engine?!
thanks
Dan
cheesesliceking
What engie size is your AX? there's a few things you can do to a 1.0 such as fitting the inlet manifold & twin choke carb off a GT, but if its injection theres not that much really. just get yourself a GT or GTI.[:D][:D]
Also if you are bored some time check out http://www.axoc.co.uk its the AX owners club!
Cheers[8D]
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ZXturbo_Aura</i>
thanks
Dan
