Bumping noise from suspension.
Piet
Unread post by Piet »
the noise is onlt evident when a sharp bump in roadway is hit. Sounds like when the tyre is hit with a rock, not a metallic sound. Left front suspension.
KennyW
x 165
Re: Bumping noise from suspension.
Unread post by KennyW »
Welcome to the forum, they only way to find the problem is to check all you rubber bushes on the front suspension with a lever looking for excessive movement.
Very difficult to diagnose the problem with the limited info provided.
Kenny
C3 1.4 petrol (SWMBO)
quintet
x 44
Unread post by quintet »
The early c3's were a little prone to snapping the suspension springs but thats quite easy to spot so my first guess would be one of the ball joints being worn on the antiroll bar linkage.
Music keeps me going.
