CITROEN DS4 RNEG 2 Buttons not work as need
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
vainn
Unread post by vainn »
Hello, I installed 2.86 SW on RNEG2 on DS4 ( back-uped internal SD) now I have Peugeot logo on start screen and buttons not work as need e.g. when I press on SETUP button it goes to Radio.
Thank you
Reason: Moved to RT6 Forum
x 6945
Re: CITROEN DS4 RNEG 2 Buttons not work as need
You need to read the first post in my guide here:
viewtopic.php?t=63227
It shows how to extract the files from the internal MicroSD card using Mirascripts in Part 1 and to copy them back in Part 2 of the guide at the end.
Regardless if you have replaced the SD card or not the same applies to copying and restoring the user data.
If you have not done this then you need to locate the files manually and restore them - but beware this can cause more problems as Windows will create system files on the SD cards once you insert them into a Windows PC. These can be hidden, and will need to be removed before you reinsert the MicroSD card.
What has happened is your unit has reset to a default configuration as explained in the guide.
vainn
Thank you for your help, but I can't make WRITE user_data on RNEG2.
I just have read user_????.dat from RT6
x 6945
See the Mirascripts Part B instructions in the first page of the post I linked to. It tells you how to write the data back.
