DPF fluid pump
Citroen_C4
DPF fluid pump
Unread post by Citroen_C4 »
Aftwr some help/advice if possible.
My Citroen C4 VTR+ 2011 1.6 started showing an engine fault. The code reader shows a DPF PAT fluid pump failure. A garage I asked to quote for repair said that only Citroen dealer can do this as it has to be reprogrammed after, is this correct?
Citroen have quoted £650 but they dont know when they can do it as the part isnt showing a date for delivery.
At a bit of a loss whether to repair (mileage is 124500) or cut my losses 😅
x 6950
Re: DPF fluid pump
It will need priming that's for sure and that is normally done with the Diagbox under replacement parts which primes the unit.(Citroen's diagnostic tool).
