Throttlebody replaced C4 - Low idle.
citc4
Unread post by citc4 »
Hello folks,
I have just replaced my throttlebody on my 2005 Citroen C4 1.6 Hatchback.
due to that the old one gave me a Throttlebody position sensor code - SERVICE
Now that i have replaced the throttlebody, it idles low, and even when i fully depress the gas pedal the RPM wont go up.
Hope someone has a tip.
Help is much appreciated!
citroenguy
(Donor 2021)
x 77
Re: Throttlebody replaced C4 - Low idle.
Unread post by citroenguy »
There might be a learning procedure needing to be done with Lexia/ other diagnostic tool.
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
citc4
Okay, thank you. So sometimes you would really have to do it with a Lexia scan tool to make it work?
citroenguy
(Donor 2021)
x 77
Yes Lexia or other higher end scantool, eg bosch, Delphi, autel etc
citc4
Okay, just bought an icarsoft EU pro diagnostic tool. That should do the trick with ETC. Thaks again.
citc4
Re: Throttlebody replaced C4 - Low RPM
Still same problem RPM wont go much up huh?
Wrong part maybe?
The original is a BOSCH and the part i have is STARK..
