Hello
Just about to have the Michelin Primacy 4's fitted to my Picasso, it currently has factory alloys and 16" tyres fitted but when I put the registration number into tyre websites it says they will most likely be 17" and offers 16" as an option so my questions, can I put 17" tyres straight onto factory alloys? Presuming a bigger tyre size is desirable?
Citroen C4 Picasso 2010 Tyre Sizes?
- x 6955
Re: Citroen C4 Picasso 2010 Tyre Sizes?
Always replace with the correct tyres for the fitted wheels. As it may of been an option to have larger wheels fitted on your vehicle they offer 2 types and the reason why you must check you own vehicle.
Your tyre sizes should be written on the label usually in the door aperture where the tyre pressures are listed. If you don't know, pop your VIN up and I'll confirm what was fitted.
ChrisPembs
Hi thanks for the reply, it does indeed say r16 on the sticker and the idea is to put factory wheels on it hence the Primacy so 16" it will be, thanks
- x 6955
Dim Problem
