Lowering and raising windows. (RESOLVED)
DamirMitrovic
x 4
Unread post by DamirMitrovic »
It happens that sometimes the passenger's window from the driver's command works normally. Sometimes he doesn't react! Also lifting and lowering over the remote sometimes works sometimes not. This happens after a BSI reset.
x 6955
Re: Lowering and raising windows.
Make sure you reset the anti pinch system on all windows if the battery has been disconnected.
  • Hold the window button down until it reaches the fully down position.
  • Next lift the button manually so that the window starts to go up whilst you are holding it manually at the first position - manual operation (don't use the automatic 'one-touch' by lifting the button fully up).
  • The window will stop several times. When it does, release and then again pull the switch up keeping your finger on it at the first notch, and it will start to move again.
  • Repeat this until the window is fully closed.
  • When the window is fully closed, again hold the button at the first position for a few seconds - you may hear or feel a feint click. This is the system reinitialised.
  • You should then be able to raise and lower the window normally without it stopping.
  • Repeat for the other electric windows that are fitted with anti-pinch.
DamirMitrovic
x 4
When I lift in the first degree. He doesn't stop alone, but goes while holding the button. Only when I release the button does it stop
DamirMitrovic
x 4
RESOLVED
There was a problem with the lift, which was not original, now it is original and everything works.
x 6955
Re: Lowering and raising windows. (RESOLVED)
Ok, great, you resolved it.
