C5. 2007 2.2 diesel clutch
colin machin
Unread post by colin machin »
Hi I have a 2,2 diesel engine with a clutch problem it's very noisy.i have priced a new one and if the flywheel is also gone it's very expensive to do even if I do it myself its time to decide what to do may be scrap it .
C5 2007 HDI
colin machin
Re: C5. 2007 2.2 diesel clutch
The mot was February and the wishbones had to be replaced,I have replaced all the brake pads and discs .it's a nice car but I'm getting fed up with the ongoing problems.
C5 2007 HDI
x 3306
The advantage about doing the complete clutch assembly is that you shouldn't have to worry about it for another decade or more.
x 6956
colin machin wrote: 14 Apr 2022, 16:00 The mot was February and the wishbones had to be replaced,I have replaced all the brake pads and discs .it's a nice car but I'm getting fed up with the ongoing problems.
The car will be 15 years plus now, so it's going to need things doing, and the clutch / flywheel are wear and tear items and a big expense, so depends on what else is likely to need doing. Some suspension struts are no longer available now, so watch for that. If you haven't had the clutch / flywheel done yet, maybe time to have a think.....
