Replacing Accelerator peddle?
tizdaz
(Donor 2022)
x 4
Unread post by tizdaz »
Hi guys, how do i remove/replace the Accelerator peddle from my C4 GP VN: VF7**************[VIN obfuscated, can be read by forum staff]
is it simple enough or do i require a degree in science!!?
Cheers :)
x 6950
Re: Replacing Accelerator peddle?
Officially you must replace the nuts if removing the accelerator and these need torqueing to 0,8 daNm.
It's just a matter of carefully removing the connector and then the three nuts.
tizdaz
(Donor 2022)
x 4
great thanks Marc :)
tizdaz
(Donor 2022)
x 4
How do i remove the connector?
Cheere
tizdaz
(Donor 2022)
x 4
Ive removed the orange clip but still cant disconnet the plug!?
x 6950
I can't tell from the image which connector it is - some of these require a small flat screwdriver to push in at the appropriate part to release, or it could be a more secure connection for obvious reasons being the accelerator, and may therefore have a locking connector that needs releasing and lifting away before it can be disconnected.
tizdaz
(Donor 2022)
x 4
GiveMeABreak wrote: 14 Apr 2022, 17:34 I can't tell from the image which connector it is - some of these require a small flat screwdriver to push in at the appropriate part to release, or it could be a more secure connection for obvious reasons being the accelerator, and may therefore have a locking connector that needs releasing and lifting away before it can be disconnected.
Cheers buddy,
I removed the orange clip & then i had to use a small flat screwdriver like you say to release the plug. I had to remove the heater blower motor as it sits right above the pedal & made loosening one of the 3 bolts for the pedal almost impossible. But once i removed the blower motor (which took minutes as ive already had this out in the past!) it was fairly simple to disconnect the plug then :)
I've also made a donation to forum, thanks for all your help, much appreciated :)
Cheers!
x 6950
Ok, thanks for the Forum donation. Your membership will have automatically be upgraded for up to 2 years. If you require any official part numbers, just put your request in this thread :wink:
viewtopic.php?t=69962
tizdaz
(Donor 2022)
x 4
GiveMeABreak wrote: 15 Apr 2022, 11:51 Ok, thanks for the Forum donation. Your membership will have automatically be upgraded for up to 2 years. If you require any official part numbers, just put your request in this thread :wink:
will do cheers buddy ;)
