508 Central Console/Navi button diagram please
pablo95
x 7
Unread post by pablo95 »
Hello, i seen back in a while a post about it but cant find it :/ probably it was deleted.
Can anyone give me a diagram of the pins of this central console/navi button diagram?
Im going to put it on my Citroen
x 6955
Re: 508 Central Console/Navi button diagram please
You won't have the wiring harness for that I suspect as these were only fitted to the DS5 on Citroen vehicles with RT6 IIRC.
pablo95
x 7
GiveMeABreak wrote: 06 Apr 2022, 22:29 You won't have the wiring harness for that I suspect as these were only fitted to the DS5 on Citroen vehicles with RT6 IIRC.
found it thanks, its the 8493 :)
x 6955
Good luck with that!
Kristids4
Unread post by Kristids4 »
Do you fit it?
bobby89bobby
Unread post by bobby89bobby »
Hi. I'm puting a Rneg2 from a 508 on a 407.
I need to wire these buttons as well.
Is that the right electrical diagram?
Can you clarify which component is which?
I was expecting a + - can hi can lo layout like the display. But there seems to be 3 wires going to these buttons. Do they wire directly to the radio? Or the BSI? Whats going on?
