LEAKING ANTI SAG SPHERE
egg
Unread post by egg »
Hello all. I have 2.0 16v Xantia, 1996, 61k. I have replaced the front spheres and the accumulator sphere recently. Also changed the lhm. Problem is lhm leaks quite heavily from the centre (anti sag) sphere on the rear (it is the non hydractive system but has the anti sag). The ride on the back end is not the best, appears a bit bouncy. I'm inclined to change all the spheres on the rear, including the anti sag. I am, however, a little concerned that there be a more sinister problem causing the leak.
Any guidance would be appreciated.
