ZPJ4 valve guides.
E M Wynne
ZPJ4 valve guides.
Unread post by E M Wynne »
I,m in the process of rebuilding my ZPJ4 24vl engine & have quite a bit of wear on the valve guides...can anyone give me a part number for genuine or a replacement guide that fits the 24vl cylinder heads...no luck on the old e-bay.
x 2943
Re: ZPJ4 valve guides.
x 1423
Unread post by xantia_v6 »
Gibbo2286 wrote: 28 Mar 2022, 17:11 Not sure if this helps. https://allparts.me/en/peugeot/605%20%2 ... 461/10477
I suspect that those parts are for the (completely different) ES9 engine fitted to the 605 and XM from 1997.
E M Wynne
Cheers I,ll check my guide specs & go from there.
E M Wynne
I know my stems are 7mm so there may not be much difference in the guides...I can modify if need be...was the 605 fitted with the ES9...I know the Renault was.
E M Wynne
Just brought up the Metalli part no. & they are for 24vl. engines from 89/94. so the correct guides thanks all.
x 1423
Fingers crossed that they are actually in stock.
E M Wynne
For future reference the ZPJ engines have a 7mm valve stem & the ES9 has a 6mm valve stem.
