Hi All,
It’s my first time here on this forum. Electric parking brake fault appeared on my Citroen C4 GP 2016 model and stayed for several days. Initially it was intermittent and then became constant fault when you open doors etc. can’t apply parking brakes at all now. After a few investigations and reading through these forums I figured that wire may be broken which in fact was the case. So I fixed and checked the voltage on both sides which is same on all four wires each side. Now even after fixing this the error has stayed and now I get a constant flashing light of parking along with other lights. This flashing light only appears when I move car.
Can you please help.
Nish
Citroen C4 GP 2016- electronic parking brake fault
Nishant1512
