Day radio updrade to Android
This section is for General Enquiries or for Systems not Covered Above
Megliam10
(Donor 2021)
Unread post by Megliam10 »
Wondering if anyone has fitted a double din or similar android head unit into the single slot factory radio. Anyone got recommendations and pics please.. cheers
x 6956
Re: Day radio updrade to Android
I think if you do that you will lose access to may displays including the hybrid. These head units are very much integrated into the Vehicle. I suspect you may have the RT6 or RD5 system fitted which is behind the fascia and the controls of which (in the case of the RT6) are on the central console for remote control and the radio functions on the fascia. None of these will likely work if you try and replace it with an android unit.
