Hi All,
Vehicle Espace Mk II 1994 Petrol 2.0i Petrol Injection. 1955cc aalso single point LPG - very good runner.
As usual in a spot of trouble - need some advice please.
The Attached image shows the inlet manifold on which there are several small bore rubber tubing connections.
I think they are all intended to operate sensors/switches based upon Inlet Vacumn
The tube marked with RED Arrow is connected correctly - no problem - I think petrol flow valve.
Problem is tube with Green Arrow which although attached at the manifold end has come disconnected at the other end.
Problem is to know where that end should be located/connected - it drops down under the manifold and is quite long - 30+cms.
I have often wondered where to - now I have to find out.
If anyone can help - really grateful - it would help to avoid much crawling underneath.
Best Rgds.
Inlet Manifold Vacumn Sensor Tube
