Headlmap adjustment C4 Grand Picasso (2014)
tizdaz
(Donor 2022)
x 4
Unread post by tizdaz »
Hi guys, where abouts are the adjustment screws to adjust the low beam on my C4 Grand Picasso (2014) ?
Ive replaced bulbs but the beam seems too high on the passenger side so want to have a go at adjusting it myself before i revert to taking it to the garage!
x 6950
Re: Headlmap adjustment C4 Grand Picasso (2014)
I would first check you have the new bulb inserted correctly - this is a classic symptom of the bulb not fitted correctly. The headlamps should not normally need adjusting unless they have already been adjusted incorrectly - they don't move on their own.
