Coolent loss
Foxykye
Coolent loss
Unread post by Foxykye »
I have pug 207 2010 sw lately im loosing coolent no overheating no mayo in oil cap after a long journey cant see any leaks but I have small leak in sump so.maybe mixed on floor I have no idea I want to take to garage but don't want him fobbing me off with gasket failure I had oit leak 2 year ago he said it was that I bought new engine had it put in but I was never sure it was head if im honest so just want a few ideas what it could be so he's not fobbing me off woman on any help plz thankyou
gwest
x 20
Re: Coolent loss
Unread post by gwest »
If it is the thermostat seal, the rear coolant pipe where it enters the water pump housing, or the oil filter /cooler seal, they can be very hard to spot. If you have coolant dripping from the sump then it may well be the oil filter housing. None of them are trivial to repair. Oil and coolant leaks are these engine's signature.
Huskyxantia
x 862
Re: Coolent loss
Unread post by Huskyxantia »
Also check the coolant pipes bleed valves they can weep too.
:-D
