Hi folks
I am quite familiar with the metallic clunk on a BX caused when the drop link has a gnat's whisker of wear in it.
What does a worn drop link on a ZX sound like? I have a noise from the front on rough (aka West Yorkshire) roads - not so much a clunk as a 'pobble pobble' [:)] noise. Cannot see any wear in bottom ball joints or wishbone bushes, boot is split on LH drop link. Ride and handling are perfect - what does the team think?
Hunt the pobble - what does the team think?
alan s
- RIP 2010
- x 6
Noises like that can also come from worn rack ends which is a ball joint attached to the steering rack, as a result, the noise tends to amplify through the actual rack. On a BX it's not a big job nor an expensive one, but on the 16Trs I had, a Cit meechanic with about 35 years experience who was the previous owner couldn't find it but it showed up at a RWC (=MOT) <i>when I sold the car</i>. The noise had driven me mad while I owned it.[:0][B)]
Jack wheels off the ground, lock the steering & grab the tie rod & push it in & out & look for wear on the inside of the tie rods.
Alan S
Alan S
VisaGTi16v
- x 1432
My Xantia used to make just this sort of noise - a light, muffled, knocking over rough surfaces - very different to the sharp rattle the drop links made. Fitting the new track rod end at the weekend has cured this noise. Interestingly though, on high suspension and with it jacked up, there was no play apparent, but you could rock the road wheel backwards and forwards with a definite clunk-clunk with it on the ground!
If you can get an assitant to rock the wheel while you hold the entire ball joint you should be able to feel if there is play in it.
rg
NiSk
rg -
XM suspension noise sources:
- Bottom ball joint (a real mother to get off)
- Track rod ends
- Inner track rod/steering rack joint
- Anti roll bar (in it's plastic bushes)
- Inner wishbone bushes
- Strut upper mounting (check with a sharp screwdriver around the part protruding through the inner wing - if it goes through, you have the dreaded almost-strut-through-bonnet syndrome) Lift the side of the car so that the wheel is clear of the ground - does the upper mount separate (thick rubber bush supposed to be vulcanized to the rusty steel plate you tried to stick the screwdriver through).
//NiSk
- Track rod ends
//NiSk
uhn113x
- x 3
Brian Oblivion
My pobbles get worse if I'm in too high a gear on rough surfaces. I've just had it checked by local garage and they couldn't find owt. The pobbly rattly noise is on the drivers side-front. I've just had a tie-rod done on the passenger side front, thats cured some knocking noises, but not the pobbles. Oh dear.
James.UK
VisaGTi16v
alan s
- RIP 2010
- x 6
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by uhn113x</i>
Thanks for all your suggestions, folks - NiSk - I'm glad its not an XM, then [;)]
I'll check for play in TR ends, although steering is fine and nothing can be felt through it. Will replace drop link with split boot, anyhow
"Pobble" may not be a word from the dictionary but it's a bloody good description.[:D]
The rack end noise is exactly that noise & it doesn't affect nor can it be felt through the steering. When the guy found mine I reckoned he was having a lend of me until he showed me. He had the car up on a hoist which made it quite simple to detect and even simpler to fix. He did mine in about 15 - 20 minutes.
Alan S
Alan S
Paulee
uhn113x
- x 3
Visa16GTi
'Pobble' is <b>now</b> a word - I claim rights as its inventor!
Also to 'deedle-deedle' - the noise a gearbox makes in reverse on the overrun when car has been owned by a boy-racer [;)]
Anyone know what on earth 'Zum-zum-zum' (Mazda ads) means?
Alan
It looks like this is probably the cause - all I need now is a spare half-day!
Paulee
Maybe, but there is no difference on turns nor clunks when you reverse the drive
Alan
Paulee
wrinklet1
VisaGTi16v
