Bleeding brakes part 2 .........
KennyW
x 163
Unread post by KennyW »
Hi All,
Just replaced disc and pads on the rear of C5 x 7, followed bleed procedure as per Citroen but where is Diagbox bleed procedure hidden.
Used Diagbox to release handbrake and re callibrate same.
Is it under maintenance and where.
Kenny
C3 1.4 petrol (SWMBO)
x 6954
Re: Bleeding brakes part 2 .........
Have a look under the ESP ECU if you can't find it in the repair or maintenance section Kenny. It may be there as this is related to the bleeding of the hydraulic block.
Only do the secondary procedure once you have completed the primary circuit bleeding.
KennyW
x 163
Thanks Marc,
Done initial bleed,tried to find bleeding of ABS without success will have another look at weekend.
Will get back to forum if and when I find its location.
Kenny
KennyW
x 163
Okay found the location to bleed abs hydraulic block.
Using Diagbox access the Repair box, global test, choose ABS/ traction control ECU, pick pack repair, 4 options, pick bleeding and follow the on screen instructions.
This is how it appears for my C5 x 7 2010 model.
Kenny
