Remaping Citroen Relay / Jumper 2.0 Bluehdi
pattap
Locked user account
Unread post by pattap »
I can see quite a few topics on remapping other models but haven't found one on Citroen relay/jumper.
I have 2.0 bluehdi with DW10FU engine from 2016. I think it's 130bhp variant if to trust v5 document.
Have anyone remapped their vans? I'm wondering what is a safe limit etc. It's a camper conversion not sure of the weight at that point.
Any input will be much appreciated.
Pat
pattap
Locked user account
Re: Remaping Citroen Relay / Jumper 2.0 Bluehdi
Doesn't seem to be a common one
x 6950
It's a very grey area to be honest as you really need to consider the impact this will have such as increased emissions as a result - at a time when MOT requirements are stricter than ever before, so you may run a risk of increased smoke. A 10% increase in the fuel mixture can result in up to 100% of smoke. This means regeneration will happen more quickly due to increased soot, so is likely to reduce the life of the DPF. Your NOx levels will increase too, so this may be detected as out of range by the engine ECU and then you have more issues.
To be honest, save yourself the expense and potential issues with the SCR and DPF. These vehicles are already tuned to meet the emissions standards and even some untuned vehicles are having problems meeting the stricter emissions limits in the MOTs now.
