Will They Be The Same
sikez
Unread post by sikez »
After a little help if possible, Somebody has put a screwdriver at the side of the drivers door handle and bent the door around the handle, Where the end cap goes over, Not major but annoying.
The paint code shows 'EZRC' now I see a lot of adverts with the paint code 'EZR' and I see one for a Berlingo which I believe are the same?
Would an 'EZR' paint code be one of the same or does it have to specifically have the 'c' on the end.
I would be looking at the drivers side door for a 2014 1.6hdi.
Would like to get it sorted if it's going to be cheaper than insurance.
Thanks in advance for any help.
x 6963
Re: Will They Be The Same
Basically EZR is Aluminium Grey Metallic. On some Peugeot vehicles they called it EZRC, but it is the same Aluminium Grey Metallic paint.
sikez
Many Thanks much appreciated
