C5X7 2.2 Limited 2014 Sedan HDi Coolant Flush
ozzdownunder
Unread post by ozzdownunder »
Hi, what is the best coolant fluid to use?
Also, what is the best way to flush the coolant system and replace the coolant fluid.
Vin: RD4 HLAEL502511 Engine: DZ864023609 ? (Australian) it's a 2.2L diesel engine. Automatic. Sedan.
Is there access on the bottom front that I can use to either undo the water hose or tap that can be opened for this purpose? tx
x 6950
Re: C5X7 2.2 Limited 2014 Sedan HDi Coolant Flush
Guides are available in the donating members section:
viewtopic.php?t=64036
