508 Auto Wiper / Lights Issue
Iankai1
On another topic I don't suppose you would know where the day/night sensor is my lights are always on when set to auto also my wipers stay on intermediate when on auto I don't know if the 2 are related. Thanks
Iankai1
Re: U1218 on Citroen C5 X7 1.6 HDI
Thank-you I will check cleanliness and relay first
Iankai1
Sorry but to clarify that this info is for a peugeot 508 2011 .
- x 6954
Re: 508 Auto Wiper / Lights Issue
It's posted in the wrong place then - that thread is for a C5 X7.....
I've now created a new topic and moved the posts over, but deleted my post as it is no longer relevant.
Post up your VIN for the 508.
Iankai1
Thank-you so the vin is VF3**************[VIN obfuscated, can be read by forum staff] the problem is that when I put my wipers on auto they stay intermediate whether its raining or not and my auto lights stay on if its day or night. Thanks
- x 6954
So best thing you can do is get it diagnosed with Diagbox, as you may have a problem with the control module in the steering wheel which is responsible for both systems. It can't be any of the fuses as the lights and the wipers are working, so likely to be something in the aforementioned module or the CAN communication from the module to the other systems like the BSI, engine fusebox or supplies unit.
Iankai1
OK thanks for the quick reply I will try to did someone with diagbox
- x 6954
If you get any fault codes, pop them back up.
