Hello again ,
My 2005 C4 has thrown a spanner at me again. Its done 380.000km full sevice history
I was driving at 70kph, tractor ahead of me so I slow and the road ahead it clear with a slight incline , I dropped it down a gear or 2 start to accelerate to pass the tractor and then BAM !. Engine light on warning beep Antipolution warning on the LCD and oil pressure warning flashing up and a stop light and the engine cuts out at this point the Tractor passes me .
Start the engine again and Anti polution warning on and engine management too . The car runs ok but it wont go pass 3k revs without cutting out the engine but only up hill . On the flat its ok if i go steady through the gears not an issue.
Ran through code reader no anti pol codes
code for diesel pump . Reset all codes and all good .
code for my cruise control that has never worked
Checked the oil level
Cleaned the DPF
Any help welcome please.
C4 2005 1.6hdi Engine ,Antipolution, stop beep Help
Rochy101
Currently driving
2005 C5 Estate 1.6hdi aka "Duggy" rhd
2006 C5 Estate 1.6hdi aka "Cissy" rhd
1990 Ax 1.1 aka "Baggy" Lhd
- x 6955
Re: C4 2005 1.6hdi Engine ,Antipolution, stop beep Help
We'll need fault codes - bear in mind generic fault code readers likely can't read constructor codes - only generic codes, so you could be missing some. If the engine has gone into backup mode (reduced power mode) it will be an engine fault and a code should be logged. Many backup modes will disable cruise control as a safety measure, so this again suggests there is a fault there that is preventing this from working.
Rochy101
Hi the first load of codes were as followsGiveMeABreak wrote: 31 Jan 2022, 16:25 We'll need fault codes - bear in mind generic fault code readers likely can't read constructor codes - only generic codes, so you could be missing some. If the engine has gone into backup mode (reduced power mode) it will be an engine fault and a code should be logged. Many backup modes will disable cruise control as a safety measure, so this again suggests there is a fault there that is preventing this from working.
9C92 cruise controller ( this has never worked or been the issue for me )
P0606 Ecu
Currently driving
- x 6955
I'm not getting anything for P0606.
9C92 has no descriptors other than Cruise control and speed limiter switch fault: Coherence.
