Looking for above diagram to help identify problem reverse lights are working but brake and tail lights are not.
Kenny
Wiring diagram for rear tailgate lights - suspect broken wire
KennyW
- x 165
C3 1.4 petrol (SWMBO)
- x 6957
Re: Wiring diagram for rear tailgate lights - suspect broken wire
Here you are:
KennyW
- x 165
Thanks Marc
KennyW
- x 165
Okay quick update, new bulbs fitted to both rear fogs lights and tail. Fogs working both taillights not.
It’s a 6 pin plug with 4 wires
Is there a diagram for the plug to I’d which is which.
Will need to strip down tailgate for access.
But still suspect broken wire where harness enters boot
- x 6957
Kenny, these are all different for each set of lights, added to the fact you have some lamps on the body and some on the tailgate.
Which specific lights do you want? Rear Tail, Rear Fog, Rear Brake, (Reversing You have above).
KennyW
- x 165
Thanks Marc,
On the tailgate there are reverse, fog and tail lights.
The fog and reverse are working, I need to know which wires are for all three.
Kenny
Kenny
- x 6957
Boot Lid - Right Hand Side:
Earth: Pin 3
Fog Lamp: Pin 4
Tail Lamp: Pin 2
Reverse: Pin 5
Boot Lid - Left Hand Side:
Earth: Pin 4
Fog Lamp: Pin 3
Tail Lamp: Pin 5
Reverse: Pin 2
Earth: Pin 3
Fog Lamp: Pin 4
Tail Lamp: Pin 2
Reverse: Pin 5
Earth: Pin 4
Fog Lamp: Pin 3
Tail Lamp: Pin 5
Reverse: Pin 2
KennyW
- x 165
Perfect Marc
Kenny
Kenny
KennyW
- x 165
Re: Wiring diagram for rear tailgate lights - suspect broken wire FIXED
Finally got round to the rear tail lights, spliced in new wiring and working again. I didn't realise, how many times I've been here before.
Kenny
Kenny
- x 6957
Magic Roundabout syndrome Kenny.
