How to cancel under-inflation detector ECU?
CitroenForFree
Unread post by CitroenForFree »
I get a nottification that my right front tyre isn't inflated enough and I don't even have the transmitter module on any tyre. I know whitch fuse it is [F10 15A fuel additive injector - under-inflation detector ECU] , should I just take the fuse out?
x 1052
Re: How to cancel under-inflation detector ECU?
Unread post by wheeler »
there may be more than one system for each fuse so removing the fuse may stop something else working too.
You need decent diagnostics (like Diagbox) to un program the system from your car.
CitroenForFree
On the same fuse is 'fuel additive injector'.
x 3296
CitroenForFree wrote: 28 Jan 2022, 15:47 On the same fuse is 'fuel additive injector'.
Definitely DON'T unplug that fuse then, otherwise the relevant emissions filter will get blocked up fairly quickly!
