Peugeot 3008 2015 system update
banex
I am looking for the latest system update file for my Peugeot 3008 year 2015. Any help please?
- x 6960
Re: Peugeot 3008 2015 system update
I doubt you'll have a MyWay system for a 2015 vehicle... I'd expect either an RT6 unit or SMEG. Pop your VIN up and I'll be able to confirm what you have.
banex
- x 6960
Ok, so you have a December 2014 build date, and an RT6 Head unit as I suspected.
- x 6960
I've moved this thread to the RT6 Forum.
So what firmware is your current unit?
Start car, press SETUP button for about 3 seconds, then select 'radio-telephone diagnosis', then select 'Unit Description' and let me know what it says.
banex
ok I will check this evening when I get home and let you know, thank you.
banex
Unit reference 9809245477
Cd number 8785
SW version RNEG2.80.E.2
Cd number 8785
- x 6960
Ok so you are on the second to last firmware. The last is version 2.86, but I would recommend not updating it unless there is reason to do so.
Having said that, my table suggests that a direct upgrade from 2.80 to 2.86 should go on without an issue - but I can't guarantee it.
banex
If you were me would you leave it as is?
- x 6960
Yes - if it isn't broken, leave well alone. There have been some additional issues with applying the 2.86 update - like a Bluetooth echo fault on calls which may need a calibration file applying by the dealer after the upgrade, so if it's working fine now, I would leave it. You already have a high level firmware which has most of the bugs fixed.
banex
Ok thank you for your help
