Expert van Fuel Lines
Mel B
Unread post by Mel B »
I need to get the fuel line replaced between the tank and the filter.
The floor of the van is covered in plywood. Can anyone give me the location of the inspection cover because I'm assuming that it needs to be removed to connect to the tank.
If I'm wrong please advise.
Better still. If anyone is up for this paid job in WA13 shout out!
x 1052
Re: Expert van Fuel Lines
Unread post by wheeler »
I dont believe there is an inspection panel on the Expert, You shouldn't have to fully remove the tank to get to the pipework, you should be able to support it & just drop it down at one side.
Mel B
Great! Thanks for that!
