boxer wiring/relay diagram
jasper3055
Unread post by jasper3055 »
Has anyone got a link as to where I can get the wiring diagram for aa Boxer 2009.
I can only find the fuse box layout on line but there is a lack of information as to where the relays are i.e. shows you pictures of them but does not tell you which one is which.
I am also looking for the relay for the electric windows
Any help would be apprecated
x 6957
Re: boxer wiring/relay diagram
It’s very likely tat the relays are integrated into the fuse box and not user serviceable.
Pop your VIN up (automasked on post submission) and I’ll have a look,
jasper3055
The relays are replaceable as I have been pulling the out looking for a power drain. Unfortunately the van is away at present so I don't know the VIN off hand.
x 6957
There are quite a few variants of these - but they are essentially Fiat Ducatos, so have different electrics to proper Citroen / Peugeots, so as you say have more accessible relays.
x 1056
Unread post by wheeler »
jasper3055 wrote: 27 Jan 2022, 23:23 Unfortunately the van is away at present so I don't know the VIN off hand.
Do you have the reg number?
jasper3055
SL59SGO
2.2Hdi 120
x 1056
VIN is VF3**************[VIN obfuscated, can be read by forum staff]
x 6957
Ok, thanks, I'll put something up shortly.
x 6957
Ok, these are what I have. Click images to magnify.
Passenger Compartment Fuse Box, (Driver's Side)
Relays
R1 Dipped Beam Relay
R2 Heated Rear Screen Relay
R3 1 Services Relay (+KK)
R4 2 Services Relay
Engine Compartment Fusebox Relays
Relays
R1 Horn Relay
R2 Front Fog Lamp Relay
R3 Main Beam Relay
R4 Windscreen Wash Pump Relay
R5 Refrigerated Air System Relay
R6 Free
R7 Fuel Pump Relay
R8 Low Speed Fan Supply Relay
R9 High Speed Fan Supply Relay
R10 Engine ECU Relay
R11 Air Conditioning Compressor Relay
R12 Headlamp Wash Pump Relay
jasper3055
OK Thanks for going to the bother to find this for me.
However it does not show me the relay which controls the drivers side electric windows.
Do you have any idea where this will be located?
x 6957
Relay 4 in the first diagram I put up in my previous post.
jasper3055
Thanks. I have removed this relay when testing for the power drain. No effect. However I then thought I would try removing fuses when the engine was running to see how much current was being drawn across each fuse. I found that fuse 47 (power windows) had a reading of over 10A even although the window motor wasn't being used. I compared it to fuse 48 (passenger window) and got 0.2A. The fuse wasn't blowing as it is rated at 20A so where could this continuous loss of current be leaking from?
This drain is the same amount when the engine is switched off .
However when I pull fuse 47 with the engine off this has no effect on the drain, it is still there.
I also noticed 0.6A being used by the central locking.
Do you think that the wiring harness from the back of the BSI unit could be chaffed at some point?
The van is away at present but I will have a look at the window motor when it returns unless someone out there can solve this riddle.
