Boost issue
Daveinbridgo
New User
Boost issue
Unread post by Daveinbridgo »
Have changed starter motor on peugeot partner and now have no boost,won't rev over 3000rpm ....eml comes on in morning , but when I go to it in the afternoon it goes off, there's a slight leak on vaccum boost pipes which I must have done while changing starter.
Where do they run to and from as they are stuck round back of engine.
x 1240
Re: Boost issue
Unread post by Peter.N. »
Vacuum pipes are the usual culprits but some aren't easy to find, trace them along in the engine bay. After I changed the starter on my C5 I had no boost at all, I gently pulled on all the pipes I could see and found one that was disconnected, finding where they came from is not always easy either, a bright light might help.
