306 starting
froggy
(Donor 2026)
x 4
306 starting
Unread post by froggy »
Hi, my wifes 306. we changed the battery last week, thinking the battery was duff! The car has let my wife down twice, the car does'nt seem to engage with the starter. all the lights come on the dash but it does'nt engage. my wife waits a few minutes , tries the car and it starts!!!! anyone got any ideas , cheers Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
picassodad
x 15
Re: 306 starting
Unread post by picassodad »
306, petrol, diesel, year, automatic ?
On initial trying to start the engine, key in start position, any clicking noise ?
In the start position, do the dash lights dim a bit ?
Are you confident using a multimeter and working under the bonnet ?
Find the starter motor, when key in start position, give the starter motor a tap with a small ( small hammer ) hammer or similar, did it work ?
froggy
(Donor 2026)
x 4
Re: 306 starting
it's a 1.4 petrol. the lights on the dash stay bright.
Terry
picassodad
x 15
Re: 306 starting
Did you give the starter a tap when ign in start position ?
moizeau
x 429
Re: 306 starting
Unread post by moizeau »
When you say 'it doesn't engage the starter' do you mean the starter spins but doesn't engage the flywheel, the starter solenoid clicks but doesn't engage the starter, the fuse board clicks but the starter solenoid doesn't or finally...nothing happens at all?
Depending on the answer, various simple tests can be done.
Pete
