XM 11 XUD11BTE Camshaft
wesacosa
(Donor 2021)
x 3
Unread post by wesacosa »
Hi All
would anyone happen to have the diagram showing the cam cover bolts for a 1997 XM 2.1 XUD11BTE
I can't remember which position takes the bolt and which position takes the three studs
thanks
Reason: Moved Out of Parts Request to Technical Forum
x 6957
Re: XM 11 XUD11BTE Camshaft
Any good?
x 1488
Parts database is not helpful...
9 is stud and 8 is bolt. There are presumably things that attach on top so you should be able to work out where to put them.
x 1751
Wes,
Ask the QQ on XM Forum - any number of 2.1 owners there would have a look at their cam cover for you.
wesacosa
(Donor 2021)
x 3
thanks all. I think I figured it out. Two seem to be studs which don't have attachments,. but my confusion was because I thought a pipe clip went on a cam cover bolt but turned out it went on one of the inlet manifold fixings.
