Hi guys!
I’m in the process of mounting an LED light bar on my 2010 peugeot 3008 1.6 hdi, but I’m struggling to find the wire from the switch to the high beam.
I have disconnected the socket from the headlamps and measured wirth a mulitmeter, but no luck. Suspecting that it shows constant current as long as it’s disconnected, but I might be doing something wrong.
Does anyone know wich wire i connect to, or how I can locate it?
High beam wire 3008 1.6 hdi (2010)
moizeau
- x 429
Re: High beam wire 3008 1.6 hdi (2010)
Either nick into the high beam wire that goes to the bulb through a relay with a fused feed or just run a switched fused wire direct from the battery. Old school still works.
Pete
JohnMuppet
Thanks!
Was planning on doing so, but I couldn’t figure out which wire that was the high beam positive since I got 12v constant current on all the potential wires.
Tried measuring directly inside the housing and got 12v constant there as well. Seems like it’s a negative trigger.
Does anyone know if this is common on Peugeot or other psa vehicles?
- x 1056
Cant think of any PSA vehicle with negative operated exterior lamps.
What are you using to check the power at the lamp? i would use another filament (not LED) bulb to check. This should be very simple to identify so im not sure what you are doing wrong?
