Clutch kits
Gregor
x 15
Re: Clutch kits
Unread post by Gregor »
[Hi I had that problem twice so far. first at 40.000 km from new. Started to slip in 5th and 6th gear and was replaced under warranty by dealer (clutch + DMF). Second one started to slip after exactly the same km mark but was out of warranty already. It worked from 80kkm till 235 kkm. Sliping for a day or two then working normali for few days and made a slip or two again then working normali for next few days.... Installed a LUK DMF, shaft seal and now passed 37 kkm and waiting to see if it will survive 40 kkm mark! [-o<
Driving Citroen is a diagnose!
Steveo
x 13
Re: Clutch kits
Unread post by Steveo »
Thank you for information
Mine has not slipped since
Regards
Steve
x 1222
Re: Clutch kits
Unread post by Peter.N. »
I have just noticed that clutch kits have got much cheaper, LUK clutch and flywheel for the C5 for less than £300.00 on Ebay.
Steveo
x 13
Re: Clutch kits
Hi Peter
Do you have a link (just in case)
I've seen some that say they are LUK but the original packaging is removed and replace with a plain box Mmmmm.
I have seen them for less than £300 ,some are solid flywheels and some are cheap rubbish .
Thank you
Regards
Steve
x 1222
Re: Clutch kits
https://www.ebay.co.uk/itm/153722100443 ... BMgKmAiMBf
Seems ridiculously cheap, I would be interested in your observations. No mention of the clutch in negative feedback.
Steveo
x 13
Re: Clutch kits
Hi
Can't really go wrong if it's a genuine luk kit although no good to me as mine is a 2.0 hdi and so not compatible
Regards
Steve
