I'm hoping someone has had similar problem as to this one.
Car has run fine with no issues, then the other refused to start. Turns over but not attempting to fire. The car is stick in eco mode regardless of how much power is in the battery (had it on jump from my car). Also have NO engine management light come on with ignition and have a _ _ _ _ _ _ flashing on the oil.
I've put a new crank sensor on and checked all the fuses, the earthing points and ecu connections which are all clean and dry.
I'm fearing the worst but hoping someone can help ??
