Yesterday morning the Air con fan stopped working...the previous night I was using the X-mist sanitizer for cars and according to the can I have to set the aircon to low heat and high speed. Then while the sanitizer is working (about 15 minutues) you leave the car running with the aircon running on low heat and high speed...this is what I did and all seemed ok when I stopped the car about 15 or 20 minutes later. However, as I said, when I was going to work the following morning the main fan did not start but the rear fan is working fine...Any ideas? I have used this sanitizer before without an issue...
Thank you
Doddi
