Hi, Could someone tell me if a 2013 passenger door will fit on my 2016? they do look the same but i dont spose that means owt.
Any help appreciated
pete
DS5 Passenger door
- x 6950
Re: DS5 Passenger door
There were some differences for those with 'upper side bumpers' and those without, up to and then from July 2012. But the other issue you need to consider is the internals.:- with / without hands free access and then the mirrors which some had blind spot monitoring and others didn't and other options - to consider.
ped1966
Thanks for that,so if i took all the electrical bits off my door including handle and mirror i should be ok?its just the door skin thats damaged on mine
pete
pete
- x 6950
Ok, so just keep the same internals as you have and you shouldn't run into any issues - we do know that connecting control modules for other options can cause a problem with existing equipment, so just replacing the door skins should be fine.
