rneg firmware update
This unit is the MyWay system, also referred to as RNEG, made by Harman Becker.
Main Features: Also referred to as RNEG, the MyWay colour satellite navigation system, has SD card, integrated European mapping, live trafic information, voice guidance and graphics in 2D or aerial perspective & it features a Bluetooth® system (Bluetooth phone compatibility only - no Bluetooth Audio Streaming).
mistermas
Unread post by mistermas »
hi does anyone have rneg r50b ? or know any links where i can download
thanks
clinic
Re: rneg firmware update
Unread post by clinic »
Hi, that's my first post, I looking for maps for my peugeot 308 from 2010, that what I know currently it's something like this, rneg_D_R27bis_R27.01 but I'm not sure what I need to look, what I need download or install to update, currently I don't have any SD card inserted, but not sure what maps or soft I need to download, anyone can help me with that? thanks
x 6945
@clinic:
We don't supply maps or provide links to them here apart from the official site. That reference you quoted is for the firmware, not the maps. They are two separate things.
Official Link to Maps:
https://citroen.navigation.com/home/en_ ... enEMEA/EUR
clinic
@GiveMeABreak
thank you for reply, did you know if I need first upgrade firmware or I can just add maps on this one?
thank you for that link, but link it's for citroen and my VIN number don't work here so I can't find which map version I need.
x 6945
clinic
So I got maps "RNEG (MyWay-WipNav) Cartographie 2018-2 officielle PSA" and SD card SDHC 10 16GB, I format SD with MS-DOS (FAT32) and named DATABASE, on main path this SD I got folder called "database" and inside this files and folders. But nav still don't recognise maps 🤷??? any idea what I'm doing wrong? where can be problem?
x 6945
This is not an official map that you have, as officially, they supply the SD card itself when you purchase it, so there is no copying of files needed.
So wherever you have 'obtained' your map from, I suggest you go back to them for support
