Hello,
I am new on this site.[:I]
Does someone know the exact output voltage on the map sensor when the car is idling?
Car is a XM v6 engine year 1998, engine ES9J4
Mine is giving now 1.4 volts at idle wich is I think a little bit too high.
(Sorry if my English is not so well, i am Belgian)
greetings.
someone knows the exact idle map voltage ?
alexx
XM-V6
Thanks Alexx,
yesterday I did teh measurement on my peugeot 206 1.1 (it has almost the same type sensor) an came to 1.485 v at idle (cold engine) and 0.8v when decceleration after pushing the throttle at stationairy.
the car runs quite good but i feels more like a 2.0 litre engine than a v6. What can be wrong else ?. The lambda sensor is already replaced by the dealer. By 2100 rpm it feels like the engine shudders above 4000 rpm it pulls like a rocket.
alexx
Well, it's hard to tell. I also have a slight problem with my Xantia (1.8 16v), which didn't show up on the diagnostic device - when I push the throttle quickly, there's a short delay before the engine reacts, and then it reacts abruptly, on off/on fashion. This delay is short (about 1/4 of a second), but a bit disconcerting. I'm planning to check MAP sensor and throttle potentiometer manually, but didn't have a time yet.
About the lambda sensor, when you push the throttle quickly and/or fully, it's input is disregarded anyway, and ECU relies on main fuel and ignition map (manifold pressure vs. rpm).
It would be a good idea to test voltage on the MAP sensor with engine stationary and ignition off also - should be about 4.5 V or above. With engine idling, voltage should also reach near that value on brief throttle kick (on my case, diag. device was showing up to 980 mbar, which I suppose is normal, since there's almost no vacuum at that moment).
XM-V6
alexx
David Goddard
For the ES9J4:
5V feed to the MAP
4V signal from the MAP with engine stopped.
When engine starts it should quite quickly drop to 0.7V
No drop equals faulty sensor.
Or:
4-5.8V at 0 m/bar vacuum
2.5 - 3.7V at 300 m/bar vacuum
1.3 - 2.0 V at 600 m/bar vacuum
Source: Car Mechanics Magazine - February 2000
5V feed to the MAP
Or:
